Hey everyone, its been awhile since i could get on. And hopefully i can upload some pictures of my P5 when i get the appropriate chance. But in the meantime, i have a problem. Now when this happened, it was right after school, and i was taking my friend home(wasnt far from my home). After i dropped him off, i got to the red light before going up my road to my place, and im sitting at the red light and notice light steam coming from my side of the hood( my coolant reservoir tends to bubble, shake, and steam. And also my coolant reservoir has a good inch and a half crack on its side which i dont remember it being there.) So then i quickly turned the car off as i seen the temperature gauge go up. After the light turned green i started it back up and rode past the light and parked it, because the temperature was going higher than normal temperature. And the weather was pretty cold, and plus it was raining. So i eventually got it up to my place, parked it, and then i watched the temp gauge when i took it out of gear, When its in drive, it gets hotter, but if its in park, it cools down a bit. Then like a day or two later, i went out and started it up. I let it run til it got to normal temperature. But it definally idled very differently, like the RPM's were first idling at 2,500 rpm's, then after oil started warming up, it periodically lowered its rpm's til it got around 1,000 rpm's.( the usual idle is 1,000 rpms, but it sometimes likes to idle under that around 700 rpms) Then after i turned the car off and checked all the caps and such. i checked the oil reservoir, i dont now if thats supposed to be full or not, but it was completely empty, and there was light white smoke coming from inside there. I also heard these ting noises almost every 5-15 seconds when the engine was running. Basically like a electric stove getting hot and you hear those tings. And plus all the coolant has disappeared with no apparent leak.
Now, to be honest, and im sure y'all won't care much, but im in the roughest point in life I've ever been. Im struggling to get a job, basically money is a severe problem. So im hoping to get off my feet soon and get hired somewhere, as my car insurance is due next week, then my phones off, so theres almost no chance of a job. And im looking for cheap ways to fix the blown head gasket, and ive heard of Bars-leak, and blue devil being able to fix this problem. Or i could just get a new head gasket, but thats a bit to steep. So i need help on whats best for this problem, if any of you have had this problem, and/or know the best way to fix it. It sucks cause i've had this car for almost half a year, and i still dont know all thats wrong with it, and a bit ironic to cause the head gasket blown a day before i was gonna take it to vo tech for a full check up.
