Doesn't do anything. Is like it's stuck and doesn't moveDoes the motor turn over and not start or does is not do anything? narrow it down a little bit we might be able to help.
Everything is goodId check your battery terminals and wiring. Most likely thing is something loose/wire corroded.
Where is it?Check your starter. My starter went bad on my wive's Camry and sounds the exact same as what you're experiencing. I replaced the starter and now I have no more intermittent issues.
