robertmazda
- 2013 CX-5 Touring
This should be an easy dealer fix.  They just need to do an alignment.  Part of that process is to center the steering wheel, then make sure the wheels are at the alignment spec.
			The dealer did an alignment & the steering wheel looked the same.This should be an easy dealer fix. They just need to do an alignment. Part of that process is to center the steering wheel, then make sure the wheels are at the alignment spec.
Then the dealer messed up. If the car is not pulling, but the steering wheel is off center, the 'toe' adjustment is off on the alignment.The dealer did an alignment & the steering wheel looked the same.
This is a good theory, and actually the only method available on certain older cars with only one adjustable tie rod. But the problem with this approach, other than the fact that the spline method of adjustment is crude and unlikely to get the steering wheel exactly straight, is that you would then have slightly less steering available to you in one direction and slightly more in the other, compared to a truly centered steering wheel.I bought a new Mazda once and the steering wheel pointed off-center on the test drive. It didn't pull or have any wheel alignment problems. I bought the car but told the salesman I wanted them to fix the off-center steering wheel. I suggested they pull the steering column out of the splined shaft and move it one spline over. I'm not sure if they did that, but the problem was fixed when I took delivery.
Alignment was in spec. Can you do a write up on how to align, you seem to know how to fix it.Then the dealer messed up. If the car is not pulling, but the steering wheel is off center, the 'toe' adjustment is off on the alignment.
Just got a 2014 CX-5 GS and the steering is exactly the same. Drives completely straight with no pull but requires a an annoying amount of steer turn to the left to get that way.
Did anyone get this fixed, if so, what was it?
The thing is, even if the alignment is within specs on paper, the steering wheel could still be off if the tech didn't take proper care centering the steering wheel perfectly before taking his readings, and then set and tested it again after he made any alignment changes, if he did have to change anything that is. So there are two opportunities right there for the specs to look good, but still have an off center steering wheel. The good news is that even if the steering wheel is off center, the tires won't wear as long as the 'total toe' setting (and camber setting) is within specs.Alignment was in spec. Can you do a write up on how to align, you seem to know how to fix it.
I have 2 CX-5s.
One is perfectly straight and drives like on rails. Perfect.
Second CX-5 is off. Steering wheel is off center and it tends to slightly pull to the left.
Anyone heard about 'steering sensor reset'?
Now,
I called the dealer about it and service guy said that "due to CX-5's sensitive steering it might be normal and there could be nothing to fix"
I'll ask them to look into this when I go for oil change.
If I use the silver trim on the bottom to judge straight up & down center, it doesn't look off centered.
