The Ohio Random Thread... aka We Should Probably Be Working
Well, finally got caught up on reading. lol
Wish you and Lauri luck Marlon with whatever life may have in store for you next. As others have said, you gotta do what is right for you. Very happy now that I bought those tix for LRP so I can see you guys again.
Looks like Phen's party was another success. I thought about coming out again but had to work.
Yea I only got 9 gallons there. But I have ran that tank through and I'm half way through another tank now. I ran half that tank from mid ohio on the track. (averaged 7mpg lol) But I will check today when I get home and near some tools. Thanks for the heads up #2. Glad everything is ok. And I had a dream last night that my VVT/timing chain went bad. Maybe I should check everything lol
That's a bad dream haha.
Man, screw water in the spark plug tubes. Miatas are really good at not sealing the wires to the valve cover. There's about no way to properly clean the valve cover short of taking it off or taking the wires out and making a really good seal with some rubber stoppers.
I fought that issue for WEEKS on the green car. It would come and go as the car heated up and cooled down. Blew air in the tubes, stuffed rags down there, massive PITA!!!!
#1 have you ever seen that feed place by Tess's house in Seville? I've driven back in there because they sell race fuel lol but That may work
There is also chippewa lake park. Its an abandonded amusment park with old roller coasters. A company was going to build hotels and stuff but ran out of money and just left after they put in dirt roads and stuff. So its a really good place to take pictures like by roller coasters and boat docks and stuff
https://www.google.com/maps/preview?hl=en&authuser=0#!q=Chippewa+Lake%2C+OH&data=!1m7!1m3!1d3!2d-81.906967!3d41.072466!2m1!2f90!4f75!2m5!1e2!2m3!1s53839648!2e1!7e10!4m10!1m9!4m8!1m3!1d514!2d-81.900387!3d41.0624269!3m2!1i1366!2i643!4f35&fid=6
Thats actually one of the places I was thinking about when I said that. There are also some cool abandoned places in Akron and Cleveland. Another option is out at summit racing but we would have to be careful to not get in the way. I just figure we need something with a little more going on than just Menchies as much as we all like out ice cream, lol.
makes sense about the bad gas, but at the same time the car was running pretty hot so I would expect that most of it should have evaporated. I also suppose they "cleaned" the other cylinders?
Karting meet is in 2 weeks, its not too late to get in on the amazing fun!!! you all love track days and autocrossing and this is another fun way to improve your driver mod in a different type of vehicle! PLUS the price is silly cheap! originally told it would be around 100 a person, but just got word that its going to be ~$55 a person now!!! seriously thats a freaking steal!! only a few spots left
http://www.mazdas247.com/forum/showthread.php?123828931-PA-OH-Karting-Enduro-September-14
My plugs are good. I don't know that it w was the gas there. But #2 you were out in the track when it was wet I was not
Unless it rained more after I left I wouldn't even consider what it did raining. More of like an annoying drizzle. It wasn't hard enough to get the track wet when I was there.
#2, after you get the car back you should bring it over so we can check compression and see where you are at.
I want to do a compression test on the MSP sometime just to see how bad it might be. Completley stock motor with with 230k+ on her and with 9-10lbs of boost. Can't be that great.
I got the car back last night and I've put about 50 miles on the car so far without any issues. No CEL and no misfires.
Ya I was out on-track when it drizzled for like 2 minutes.
It didn't rain at all after you left. And I agree, it barely drizzled, but just enough to get turn 1 slightly slippery.
Thanks, I'll have to stop over so we can do that. The issue is finding the time to do it since I'm packing tonight and tomorrow, then moving this weekend. Do you think I should do it ASAP? Or is it safe to wait until next week?
Is it possible the water has been there for a while and my issue only happened from something due to racing? On the Mazda tech sheet, it only mentions water in cylinder 1 plug hole. I swear the service manager said they found it in cylinders 1 and 4 when I talked to him over the phone, but maybe I misheard him. Why would water be in 1 and not any of the others??
Which cylinder would be considered #1? My guess is that's 1st cylinder starting at the left side of the motor right? Now that I think about it, I do remember something odd I saw when I replaced my spark plugs a little over 1 year ago. The first cylinder spark plug and spark plug hole on the left had some corrosion on it (no standing water though). I'm glad I save all of my phone pics, found the ones I took of it. This was back when I still had a TMIC at 70k miles. I noticed the TMIC core covered all of the cylinders, except the far left one.
Here's what cylinder 1 looked like on 4/2012:
The other 3 looked perfectly clean like this:
I never experienced any misfires back then so I just cleaned it out and went on my way.
I'd consider replacing the rusty coil, as that rust could continue into corrosion and eventually fail from just that. Then use extensive amounts of die-electric grease
That's pretty crazy #2. Hopefully your problem was just from a bad seal on that boot.
Ya I suspect a bad seal. I'm probably going to look into replacing all 4 coil packs and spark plugs in the near future. The coil packs have 109k miles and the plugs have 38k miles. I believe the maintenance schedule says to replace the plugs every 60k or 75k miles. I figure I might as well replace them in case the water issue did anything to the plug.
