The stock fuel pump is specified to be healthy if the maximum pressure is in a certain range. The upper limit for this is 92 psi. The lower limit is under the 86 psi that is theoretically desired for a 6 psi boost - I forget the exact number right now. 64? Anyhow, production variances can mean that one pump is fine (but on the edge) and another is not quite strong enough. Keep in mind that Corky's testing was done through a stock O2 sensor, and they get unreliable at rich readings and at high temps - ie, turbo cars. We've got a wideband O2 that will give a much more accurate picture.
We're looking at options. We may be able to get more pressure out of the stock pump. We may find once we're on the dyno with our wideband O2 hooked up that we don't need 84 psi of fuel pressure (it wasn't plumbed in for our initial dyno runs). We may find that the stock pump can deliver the 84 psi but will eventually fail (as on the Miata).
This is why we have our own P5, our own dyno and lots of instrumentation. If we find that something is needed to safely turbocharge a Proteg, it'll be included in the kit. We don't like blowing up engines at all.
Keith
