I have a problem...
No, I really do, but more on that in a second.
I went to a salvage yard this weekend to look at another 929 brake booster/MC combo. They're in great shape and the price was right but the car is buried under a "stack" of three other cars. The yard is going to uncover the car and pull the parts for me this week so I can pick them up next Saturday.
Here's where I have a problem. While waiting for the paperwork to go through on a whim I asked, "Do you guys have any Miata transmissions?" To keep a long story short I ended up coming home with this:
It's a 5-speed transmission out of a '96 Miata with 6x,xxx miles. The input/output shafts turn freely and smoothly in all gears, the price was right, and I was able to take it home the same day so I snagged it.
Up until the early 2000's Mazda only had two types of RWD manual transmissions: types "M" and "R". There have been several revisions and upgrades to each but they've remained essentially the same. The "M" transmissions were found on lower-powered, N/A cars: old RWD 626's, N/A RX-7's, older B-series pickups, and Miatas. The "R" transmissions were beefier and were found on the RX-3's and RX-4's, turbo RX-7's, and newer B-series pickups. Basically, whatever transmission you have you can swap it for another of the same type with a little work. In my case the gear set from a Miata can be swapped into my transmission by swapping the bell and tail housings and doing some slight machining to the input shaft. Aside from the old RWD 626 gear set, which is outdated and weaker, the Miata gear set has the closest ratios. In the end I'll end up with and updated gear set with slightly taller 1st, 2nd, and 3rd gears and a much shorter 5th gear. With this setup I should only have to shift into 4th on the front straight at Mid-Ohio.
So onto some work. Those more familiar with my "build" should remember a picture similar to this when I smashed the speedometer drive gear in my first transmission.
In similar fashion the bell housing is removed exposing the input shaft and bearings as well as the 1-4 gear sets:
I then proceeded to break down my spare RX-7 transmission to the same level. The RX-7 transmission is the one with the big harmonic balancer on the output shaft:
I decided to call it quits at this point. I'm a little stuck because I don't know if I have to swap the output shafts to keep the harmonic balancer, if I need to swap the 5th/reverse housings, and if there's an easier way to remove the input shaft than described by the FSM, which is basically taking the whole things part. When I get all that figured out I plan on fully cleaning up and painting all the housings and replacing all the necessary seals.
At this point I think I've officially messed with every inch of this car.
