I picked up the rear stationary gear and input shaft last night. Fortunately it looks like the machine shop guys did a good job (not like I should doubt a machine and die shop). Groove in rear stationary gear:
I'm not sure if I ever explained why this was needed. All rotaries seal the rear stationary gear with an o-ring. In RX-7's the o-ring sits in a groove in the stationary gear but in RX-8's it sits in a groove in the rear housing. Since I have a RX-7 rear housing and a RX-8 rear stationary gear I had no groove to speak of so one needed to be made. I wasn't able to get good measurements of the groove myself so I gave the shop my stock stationary gear to use as a setup. I plan on using a little RTV in addition to the o-ring so a little error shouldn't be that big of a deal.
And here's the input shaft. Fortunately it looks like the turned out correctly. Modified Miata input shaft on bottom, stock RX-7 on top:
A quick check shows the overall length and spline length to be a little longer than the RX-7 shaft but I verified the dimensions with Mazdatrix's recommendations and I trust they know what they're doing so everything should work. If not, there'll be hell to pay.
The fiberglass body parts were delivered yesterday too (busy day).
Shine Auto vented hood:
The hood is latched in above picture but not bolted to the car. It lines up fairly well but I'm going to have to lower the latch quite a bit it seems. It's a true vented hood:
I'll be tying the vent into some kind of post-radiator fan ducting eventually.
Shine Auto Fenders:
It's a pretty subtle flare but should be enough to cover the wider wheels and tires:
I've got family visiting this weekend so I won't be able to work on the car too much. The immediate plans are to reassemble the transmission and to mock up the body parts to verify fitment. I'll leave the final fitting and painting to the professionals. I'll be picking up a fender roller early next week to work on the rears.
