Unichip problems
Kidplay11
Mazdaspeed protege
I buy a unichip brand new thinking thad i wold fist mi fuel cut off problen .... Well i did noting to fist the problem it only increase the boost up to 9 psi peak ....... what i can do thanks daniel... Btw my car is complet stock
You may have a vacuum leak or exhaust leak before the turbo. Does your turbo manifold have all it's bolts?
yes, it had a leak on de manifold but i fixed that already and it has been working a lot better as soon as a did it solved the problem completely. and i just put 626 intake manifold .. but i had the problem before thad
and in the morning” cold start” I don’t have the problem in till is in normal temperature
you still have stock intercooler pipes, or else i would say relocate the maf to the pressure side on the intercooler. thats how i fixed mine.
Nah, you don't just relocate the maf to the cold pipe when you have a uni chip. It has to be retuned for it.
