MP5stephen
- Mazda Protege5 & Miata M Edition
Thanks! I think I'm still hearing slight clunking in the suspension. Can't pinpoint where or when it happens.
Its in the rear, this is why I switched to coilovers. If you re-used your tophats, itll get worse. What it is is that theres play beteeen the notched washer and the top hat. Most aftermarket springs arent as tall as the piston(rod) in the strut which will be about 5mm or so. Fix it now before the tophats get reemed out. I would recommend new top hats, and get at least 8 flat washers (12 or 14mm), dont remember exactly, someone correct me. 3-4 will.need to be stacked above the notched washer under the hex.bolt. Also, i,d replace the notched curved washersIbefore they strip. had pics of it on my old computer, id show you if I could. Be sure to use an impact wrench to re-install everything. I learned the hard way, thought id help someone else. PM me if u have questions, i can explain better. Im typing on a nook rightnow, excuse the lazy typing. It's quite annoying.
