Woke up early to do my 500 mile oil change. Drove to work and realized how uncomfortable my ride is. Tons of vibration, hard to steer, I LOVE IT!!!
Flickering sounds like a lack of power. Either check your connections, or get a power harness. I have one that recently has been going out, I wiggle the plug and it's back up, just a lousy connection. I plan on rewiring it this weekend
Installed some fun stuff today :D
Damn! I was hoping I wouldn't have to resort to the harness. I guess I'm glad I bought it with the kit... just in case.
As for the plugs being loose... I found out that the female side or the 9006 plug from the bulb has actually been expanding, causing one of my bulbs to go out intermitantly. I just got in there with a small flat head and squeezed everything back together and it's good as new... At least that was the problem with my DDM kit.
Good! I can't believe you bought the harness and didn't use it. The harness supplies backup power in case the the stock wiring fails to deliver the proper voltage. These ballasts have a very specific cut-on voltage which they operate at, they wont operate unless the proper voltage is supplies. Since they do draw a good bit of current, the harness with the wired in fuse acts as a backup power source allowing it to draw more current if needed, and the fuse limits how much it can draw so the ballasts don't burn out. I feel bad not running a harness. I'm going to go order one now!
Lights are gonna look badass Ty!
As for my car today...got a call from the new mechanic I dropped her off at for state inspection. He's seen the car before and has a monthly coupon for state inspection and emissions for $39.95...my regular mechanic charges $79.95. For half the price I figured I'd take the car to the new guy. Calls me earlier to tell me the front and ps motor mounts are torn and it would be $427 to replace them with the inspection fee added. Also said I'd fail for the tinted bumper lights and he won't sign off on a new sticker unless I replace them or sand the tint off. WTF....they have been that way for six years and never had any issues.
So anyone have a set they want to sell? :) Off to research just what changing the mounts will entail.
Lucky for you Jeff, the front and passenger side MM are the easiest to replace. Should take you about 2 hours (well, it would take me two turtle-paced hours). Let me double check my garage tonight if I have a spare OEM MM's laying around I can ship you.
Thanks Evan and figured they were the easiest...I know the rear is a biotch. Just hoping that when I replace the PS, I don't remove the entire inner fender thanks to rust. LOL
Luckily the PS mount is bolted to something a little more solid than the bad fender support. If Mr. Evan can't get you some used ones I'd recommend getting OEM replacements. I've tried the beck/arnley PS and front mounts, they're crap. The PS mount fits kinda crooked (the engine-side flange is visibly different from the OEM design) and most importantly, they're soft as hell.
The grille is a cmod ebay grille. It looks good, but it has a dip in the middle which makes for a gap between the hood and grille that I have been trying to get them to rectify, not sure thats going to happen though.
It's not too bad, even I did all 3 but the rear...still need to deal with that!
