Rico's build thread.
Holy crap that's a lot of DTCs!
Your poor gas mileage is probably caused by a combination of those, not just an old upstream O2 sensor =/
i guess i need to do a list of things to buy/clean. placed the codes where they seem to belong on the parts that might be causing the problem.
buy cam shaft sensor (P0171 OBD)(P0340 OBD-II )
( P0300) put it under here because all my plugs.wires and coils are new. only thing under that code will be this sensor
clean maf sensor or buy a new one (P0102 OBD-II ) (P0171 OBD)(P0103)(P0102 )
buy o2(already done waiting for it ) (P0171 OBD)
buy ait sensor(P0113 )
more then a few are because you swapped plugs. you needed to swap the solenoid not just the 2 plugs.
meaning new ones or replacements from someone to see if thats the prob right? know the name of them or part number to order them?
Yeah, that coil swap minus the solenoid is causing random misfires and that isn't a great help with your gas mileage
huh? what you mean the coils swap? lol that should have nothing to do with it i hope..
those solenoids i do need to replace hopefully i find some replacement ones soon
when i meantioned plugs i was reffering to the solenoids plug i switched them from one solenoid to another just to see if anything happened lol
Checked all sensors took out o2. Finally was able to take off egr valve and change it with a different one. Checked for vacuum leaks and Nothing. Cleaned maf and took our cam sensor and it looks normal
So from 10 codes I'm down to 2
P169 and p1250
I know one has to do with the pressure regulator it said . Should I take it off and try to clean it? Replace it? The other code I'm clueless
Ordered red sick speed horns
added spacers to the back
With No spacer
With Spacer
What y'all think ?
ill try to measure them today. they were my bros he had them sitting there doing nothing and I was bored so tried them on
Just checking since I have the same wheels. I'm curious what is needed up front to be flush. 8mm maybe
Similar Threads and Articles
