truplayax14
- 2003 Mazdaspeed Protege #354
About your clunking in back... That's probably your rear swar bar bushings that are finished. Had the same issue.
Thanks I will see that its taken care of.
Unless it has forged internals 15psi IS NOT A SAFE LEVEL OF BOOST TO RUN ON AN FSDE!!
Lower it below 10 at least, preferably 7-8psi.
Also, that car is no downgrade from an RX-8. It actually has torque as well as more power and it handles as well if not better.
If the Previous owner ran 15 psi the car MUST have forged internals, I wouldn't run any more than 9psi until you know for sure.On the boost level... I dont see a manual boost controller or anything, so until I can get one and get a stock tune thrown on the ecu, it will have to stay as is...
pretty well modded MSP you got there. Earlier you said the car had a 3 in downpipe, it looks like it still has the stock s pipe. So, it probably has a 3in j pipe back exhaust. MAM exhaust mani, 626 intake mani, dave b rings, GT SPEC bracing underneath, TWM shift knob!!! I wouldn't be surprised if the previous owner used to be on here. That car is tastefully modded!! Also, when you changed the plugs, did you gap them? Gap range for our plugs is .028-.032.
Its under the steering wheel. There are 2 switches, one is for the cut out, the other I have no idea...That's the first actuated cutout I've seen on an MSP exhaust. Where is the switch for that?
