ProjectBlack
- 2003 Mazda Protege 5
^good info, thank you. What do you recommend??
I would NEVER recommend Peal and Seal for in car, ever. The adhesive is not strong enough, the foil is too thin and again, asphalt is not a good vibration dampener. There are countless car audio people (regardless of system size) that have put Peal and Seal in their doors and in 2 years or less it has fallen off and it is at the bottom of the door. Seriously, don't recommend it, it is the wrong tool for the job. Do it right the first time, it is always cheaper in the long run.
thanks. I really like it so far.
well, you will lose you aribag when replacing the oem wheel with an aftermarket one and also the horn on some models. Im still working on getting mine working. lol
dont cheap out on a wheel if you do get one. get a brand name like sparco, momo, nardini, personal, etc. stay away from that ebay crap that bends in your hands.
you would need a hub to attach to the car, a quick release, the wheel and of course the lock. its best to stay with the same company when buying the hub, quick release, and lock. that way you wont have any issues.
What should you use, just dynomat or are there alternatives?
I wasn't aware that any companies made direct fir hub and quick releases for the Protege's. Or do you have to use a Miata or RX7 hub of a certain year?
did you use a brush, mask and spray? how did you do it!?!?!?
^ that looks really good. simple and yet effective
No problem I'm glad it's still in use almost a year and a half later.I love it! Thanks for selling it to me at such a good price (cabpatch)
Hey Brian, where did you source your '06 Mazda6 rear calipers from?
Nice parts, btw.![]()
The Shroud comes with a gasket, 100% of the air will have to go out those two holes. Don't forget, even though the rad has a huge surface area. Because the fins occupy the majority of it, a smaller area is the actual size of the passage.What's the point of the metal base for the fan's? Enhancing the effect of the fans?
Its so that the all the air passing though can be pulled from the fans. and not just flow through the radiator.
I have been waiting FOREVER to get one of these. like 2 1/2 years. I picked up the paint to color match the side skirts, and lip. Not sure when its going to get painted. but im happy to have the lip! Also predrilled the holes to fit the CS lip-lip. =)
