Washed both of my babies today!
attachment.php
Then tried on my iSport CF lip...
attachment.php
attachment.php
I'm thinking of selling the wing if it interferes with my bike roof rack....
Edit: While I was washing it I noticed that somebody (who deserves to have their fingers chopped off) keyed my driver side doors =( luckily it's not very noticeable (sad2)
Very nice!
B@t
Bought a new set of tires for the front wheels today, picked up a OBDII code reader, and then tomorrow I am going to try and get rid of this p0131 code on the damn thing.
Are you running clear bulbs under the red turn signal overlays?
Yep. And I re-wired the turn signals and reverse bulbs so they still work properly- i.e. the clear lenses are still reverse.
News boy! Ill buy the wing off you!
Oh man that Thing is sexy!
2nd dibs. PM sent.
I'm torn!! I love the wing and I really want to use it, but I also would love the money from selling it... so as long as I can have both (the wing and my bike roof rack) I am gonna keep it. But I will let yall know if I'm gonna sell it
Went to costco and walmart to see what kind of summer tires I can find for my P5. Both didn't have anything in 195/50/16, so I asked for 205/50/16 and they both had just one model for $125 and ~$200 respectively.
What tires do you guys use on the stock rims? I'm thinking of scrapping the idea of getting them locally getting some cheap sumitomos from tirerack...
Yeah, I remember when shopping for a replacement tire when I first got my P5 they said 195/50-16 is an oddball size. You'll have more options and no issues with a 205/**-16 tire.
Canadian tire has a couple new tires in the stock sizes for pretty good prices. I've got General Max AS-03 on my protege at the moment. they're on sale for 112 right now too. Not sure if you want all seasons though..
What's the largest ** I can run on the stock wheels/suspension?
I'd rather have a proper summer tire, I'm not a fan of all season rubber. Thanks though :)
Wideband O2 #1
Wideband O2 #2
Wideband O2 #3
Water Pump
Fans
Boost Controller
Oil Pressure
Fuel Pressure
Oil Temperature
RA-10
(On a separate harness)
Injectors
Ignition
TPS
CTS
IAT
IDLE
Nice Brian! Have you looked into the giant Molex connectors people are using for wire-tucks? Would make pulling the motor super easy since you just disconnect the harness at the firewall.
Some of the things I am hooking are small, but there are some that are requiring 20A so I dont think that would work..
The Coils that I am running boost 2000 Volts at 2Amp to 20,000 Volts at 0.2A so that cant go through the Mil Spec connector...
The Cam and Crank sensor lines are Shielded and seperate from the ignition and seperate from the injectors which aslo pulse like an ignintion, so I dont think that your idea would help my particular build..
The TPS is Shielded..
I could run the boost controller through it...and the indicators..
