05maz3subd
- Mazda 3 lava orange hb manual
Has anyone done the timing mod, and what exactly do you do, all it says is use 91 gas in the how to thread?
Just did it. Its super easy. you just loosen two bolts and push the plastic thing down and tighten them back up. its self explanatory once you get the shields off and look at the thing. the only hard part is getting your socket wrench on the lower of the two nuts. you have to push the timing belt aside while loosening/tightening. its kind of a pain in the rear.
That's excellent you went through a course on timing engine.*virtual cookie* (nobody)
So you claim your stating facts without any R&D on the mod and Monzta was making stuff up even though he did test, research and invested dyno time showing the difference between the two.(stfu)
Good point! Now what do I do? If it is free, do it! You just might like it. Hell your engine just might like it. Every single engine produced no matter what the displacement will put out different power/torque numbers give or take a few. Power, or mileage a gain eaither way is good right?
OK, I believe you. And I am in total agreement of the two statements you made that I highlighted.
No matter what I have done (modding) to mine, the mileage has remained relatively stable.
Ok. What is the final word? gain or not?
If you are interested in trying the mod out give it a shot but don't expect alot from it. You may or may not notice a difference. If you are really interested in improving the performance of your 3 invest in other power mods or suspension mods. Intake, header, exhaust, lowering springs, coilovers, stiffer mounts, etc..etc. (drive2)
changed my password, long story short dont leave your login info laying around so your tard brother can make you look line an @$$ online.
The statement about to be made is by the real "wanna3": CKP is the only input to the pcm that determines ignition timing (as you all know), advanced timing is achieved by moving the sensor down and is suggested to use a higher octane in order to reduce pinging and improve performance.....so pretty much what "TheBean" and Monza has stated...god how i wish i could turn back time
