New Wheels! Advan RZ
Looks like a tight fit in the back. Are you running a rear camber kit?
I have SPC rear camber arms, but I have them set at stock setting. Meaning, I have a good bit of negative camber. The reason I did this is because I knew I was going with an aggressive setup but wanted the adjustability if I needed it. Otherwise I would've left the camber arms stock.
If I had adjusted to no negative camber at all, I wouldn't be able to drive. I'd be rubbing the fenders just by pulling my car forward an inch. It would be undriveable.
When you say stock setting, does that mean you corrected them to -1* after the drop?
The reason I ask is because I am considering the same size and daily drive A LOT with this car. I don't want too much of a rake at fwy speeds, but some is OK.
Stock rear camber (at OEM ride height) on this car is definitely more than -1.
Mine is much closer to -2 (about -1.8, IIRC).
I'm at stock rear camber but lowered to the max settings on my BCs. I'm guessing about my measurement, but I'm pretty certain I'm more than -2.
