Who do you guys have install your Engine Mounts?
nondual
2007 Mazdaspeed3
Hey all,
I'm pretty sure I can't do this myself. Who do you have install your mounts? How can I find a trustworthy mechanic to do it?
You can do it alone and it onlly takes a few minutes for each replacement. There is a how - to but I don't have the link to it.
Any local shop should be able to do it fairly cheap. Takes about 10-15 minutes with a lift.
2 friends
2 jackstands
1 torque wrench
1 socket set
1 tube of loctite.
put car on jacks
unbolt 3 horizontal bolts from bracket holding rmm to transmission (engine will not move/fall)
unbolt rmm from said bracket
bolt new mm to said bracket
bolt bracket back to transmission
bolt rmm to frame
all the while torquing everything to 80ft lbs and using plenty of loctite
friends are there for several reasons:
1. to hand you beer
2. moral support
3. engine may need to be rocked back or forward a bit to line everything up perfectly
