MP3Night
MS3,Mazda3,MSP
I have started my Turbo build and hope to have a turbocharged MP3 before the summer. I have had a lot of help and have had the car for only 6 months now lol and now I want to turbo it. I'm ready for boost!
Turbo Parts: Done!!!
Parts Bought
1. Wastegate 7psi
2. Callaway Turbo Manifold
3. S-pipe
4. FMIC
5. Taped Windage Tray
6. Turbo, GT2554R
7. Oil return line
8. Oil return oil-pan fitting
9. Oil feed - turbo fitting
10. Turbo oil return gasket
11. Water feed line Water return line
12. water feed banjo fitting
13. Oil feed - adapter plate fitting
14. Oil adapter plate
15. Oil Temp Gauge (Prosport)
16. Triple Single Din gauge holder
17. MSP ECU
18. AWR Side engine mounts
20. FMIC Piping
21. Oil Pressure gauge
22. Slim Fans: 9" - 12"
23. SS AFC
24.Oil feed line
25. Boost/Vacuum gauge
26. Turbo - oil return fitting
27. Turbo Stud Replacement Kit
28. Vibrant Vacuum Distribution Block Manifold: Black
29. turbo outlet gasket
30. S-pipe -> J-pipe gasket
31. Exhaust manifold -> Head gasket
32. AEM Wideband
33. Wastegate Bracket for GT25R(GT2554R) Turbo
34. Supercharged Millenia PCV Valve
35. Purge Valve
36. VTCS Vacuum Solenoid
37. Vibrant Performance Silicone Vacuum Hose Pit Pack - Blue
38. Oil Catch Can
39. Aftermarket Air to Air Oil cooler
40. Blow off valve-HKS ssqv V3
41. Turbo XS Knock Lite
11-14-09 First part in (Callaway Turbo Manifold)
11-20-09 (S-pipe, FMIC, A/F pro-comp, MSP heat shield)
1-22-10 WGA, Oil return line, Oil return oil-pan fitting, Oil feed - turbo fitting
1-25-10 GT2554R, Oil adapter plate
1-1-10 Turbo oil return gasket, Water feed line Water return line, water feed banjo fitting, Oil feed - adapter plate fitting
2-10-10 Oil Temp Gauge (Prosport), Triple Single Din gauge holder, AWR Side engine mounts, Altered Customs Bov Pipe flange.
2-11-10 MSP ECU
2-17-10 (Taped Oil pan)
2-23-10 FMIC Piping
3-8-09
Before:
After:...coming soon
Parts Bought
1. Wastegate 7psi
3. S-pipe
4. FMIC
6. Turbo, GT2554R
7. Oil return line
17. MSP ECU
20. FMIC Piping
23. SS AFC
24.Oil feed line
32. AEM Wideband
35. Purge Valve
38. Oil Catch Can
2-11-10 MSP ECU
2-23-10 FMIC Piping
3-8-09
Before:
