(bump) for an old thread
some questions regarding ITBs:
1. How do you get vacuum for the brake booster?
2. How do you deal with idle air control?
Actually, the way I dealt with idle air control was to remove any semblance of an IAC valve (With the standalone I was running, I didn't need it) and just adjust the stop plate so it idled at around 800-900 rpm. Worked just dandy for me. =)
Whatcon? =) I dunno what that is... *grins* No air conditioning, but I ran about 900rpm-ish, which works pretty darn well. Actually stopped the dip in charge that was caused by rolling down the windows! Odd, that.
after re reading this thread... why didnt you go TPS instead of MAP?
Throttle position only represents load. It doesn't tell you how much air is being ingested.
