About to start a BIG Project...
Personally I would sell the 8, but if you insist on keeping it, here is what I would do to minimize the speakers interfering with each other and get the best overall sound.
Really its not that "I Insist" on runnng the 8. See, I installed the "Jack Placed Stealth Box" and cut and trimmed the rear interior to make it fit properly. To NOT use it means I would have to replace interior pieces that have been damaged due to the install. So, I am between a rock and a hard place unless I just leave it for looks. Know what I mean?
I with the appropriate cut offs, you should be able to make it sound great. Just be sure to not let it play too high or else it will cause your sound stage to move back.
I'm excited to see the finished results.
Never having seen one in person, I wasn`t aware of what the installation required. Set your levels the way we described and it could still work.
The comment Smoke made about not letting the 8 go too high is what I was referring to when I said you would need to experiment with the frequency at which you transition from the 8 to the rear mains. You want it to come up as high as you can without too much effect of pulling the stage behind you. This is where spending a little extra on a good set of separates that can go really low for the fronts really produces results. It is worth it to run the fronts as low as you can, even if it ends up with them overlapping the sub a bit. Anything you can do to pull the stage in front of you and anchor the sound there.
Are you having problems in 淘宝网女装 getting your penis hard? Are you having a difficult time in keeping it up? Is your partner already complaining about your performance in bed? Are you losing your sexual appetite? Have you lost your confidence when it comes to having sex? If you answered yes to these questions then it is probably best that you consider taking prescription 时尚女装 male enhancement drugs to keep your sexual appetite and sexual performance robust and full of vitality. But of course, you do not just get jjdudkk prescription male enhancement drugs over the counter. You need the approval of your doctor first just to make sure that you are safe from the possible harmful side effects of these male enhancement meds.
I don't think this will help with the speaker issue at hand...
