Need datalogs
vtakk
MPS3
can smbd post datalogs for stock/stock+sri?
I need to see AFR from dig to 4th on WOT.
thx
do you want cobb's stg 1 tune? ive got some of those.
i could flash back to the stock map n do a few pulls tonite after work.
do you want up to 4th or thru the top of 4th?
I need those with stock map - if you can flash stock and log that would rock my day.
and I dont need them after 3d..
thx man
--post stg1 - I would be interested to see those too..
ill give you all 3.
Stock
OTS stage 1
Custom stage 1
and again thru 4th or no? (100 mph ish)
what parameters do you want to see? if i do all there wont be many points to look at. less parameters, more frequency
Im interested in AFR only... (AFR + RPM + boost would be handful)
seems like I'm running too lean when lifting off the throttle quickly
not gonna lie 1st n 2nd are gonna be tough not to spin. may need to do a rolling start
I was just about to post this.. heh...
1st/2nd do with 50% throttle or whatever works for you...
I would be interested to see whats going on when you lift of the throttle while shifting.. hence no power shifting pls )
heres an old 4th gear wot log, this is a custom tune. Is the 12.5 AFR at the end what your concerned about?
not really...
I see you are in high twenties for afr when letting it go...
Th%,AFR,Boost
1.95,25.58,-12.33
1.95,29.25,-12.33
2.34,29.25,-12.33
this is what I wanted to see
when you let off the throttle the afr will always spike. it goes to infinity but the scale ends at 29 so thats where it stays.
notice the injector duty cycle is 0 - the car is not injecting fuel into the engine. so the afr goes to infinity. this is normal under engine braking, changing gears or when coasting in gear.
can't agree more. studying the log now..
