I need those with stock map - if you can flash stock and log that would rock my day.do you want cobb's stg 1 tune? ive got some of those.
i could flash back to the stock map n do a few pulls tonite after work
thx. no leave it on 3d up to 4th onlyill give you all 3.
Stock
OTS stage 1
Custom stage 1
and again thru 4th or no? (100 mph ish)
Im interested in AFR only... (AFR + RPM + boost would be handful)what parameters do you want to see? if i do all there wont be many points to look at. less parameters, more frequency
I was just about to post this.. heh...not gonna lie 1st n 2nd are gonna be tough not to spin. may need to do a rolling start
not really...heres an old 4th gear wot log, this is a custom tune. Is the 12.5 AFR at the end what your concerned about?
can't agree more. studying the log now..when you let off the throttle the afr will always spike. it goes to infinity but the scale ends at 29 so thats where it stays.
notice the injector duty cycle is 0 - the car is not injecting fuel into the engine. so the afr goes to infinity. this is normal under engine braking, changing gears or when coasting in gear.
I'm good with what you posted. thx!u still want the logs?
