M mazdasp33d Member : Mazdaspeed 3 Sep 17, 2009 #1 just installed pg inlet. my fuel trims are like above like 3,000 at idle..... help?
C chief_wiggum Member : 2008.5 Mazdaspeed3-2010 Mazda5 GT Sep 17, 2009 #2 sounds like something didn't get hooked back up; triple check your connections and clamps.
M mazdasp33d Member : Mazdaspeed 3 Sep 17, 2009 #3 everything is connected, i went back to my original setup.... and now they are even higher
T TheDoc Member : 2008 Mazda Speed 3 Sep 17, 2009 #4 LTFT and STFT are metered as percentages and max out at 25%, so I don't know where you're getting 3,000 from. It seems like you have a leak post MAF. Double check every connection.
M mazdasp33d Member : Mazdaspeed 3 Sep 17, 2009 #5 reset my ecu again... things are back to normal.. idk why that happened.
C chief_wiggum Member : 2008.5 Mazdaspeed3-2010 Mazda5 GT Sep 17, 2009 #6 mazdasp33d said: reset my ecu again... things are back to normal.. idk why that happened. Click to expand... strange...glad it all worked out. I have the PG TIP too, good product.
