i dont think you heard me GET OFF THE COMPUTER AND GO FINISH IT NOW!!!
Ok, when you start a manual car, what do you have to do? Clutch & Brake right? ok.
Well everything is hooked up but when I turn the key, it wont even attempt to start because the clutch has a sensor that goes to it, but my interior harness does not have that sensor, so even though I'm pushing the clutch in, the computer thinks I'm not since its not getting a signal, so the motor won't start.
Neox is still waking up, we need some kind of rest before we go back at it. We're about to look up ecu diagrams n s***.
did you change the starter? my car starts whether the clutch is pushed in or not, because the neutral safety switch is not connected. theres a wire under the dash that goes to the starter that had to be cut too
ok your finishing it today though right?
nope, still have the atx harness. but if you changed yours, then you shouldnt have to cut anythingYeah, starter was swapped. We didn't cut a dash wire so I'll look into that. Did you swap engine harnesses? We did. lol.
[\QUOTE]
We swapped only the engine harness, the missing link is in the interior harness.
Any clue what wire it is or where its by? color?
