no just for fun but then i got bored so i just made it to the final table and went all in for 4 hands and kept winning then lost the 5th one finally to get out
Hahaha. You just Had to, eh? Speaking of carbon fiber. I've got enough to buy shotz on. And I think I'm gana. Woot!
Worked on the car for 16hours straight(11am to 3am). Almost there, just need to bypass the clutch sensor for the ecu.
FOR ANYONE THINKING OF DOING THE ATX TO MTX SWAP:
Forget about it.
Forget about it.
lol....you and fish both.....
his update before to me was if i was contemplating swapping the P5 to boost, "F*ck it and just buy a MSP"
Ok, when you start a manual car, what do you have to do? Clutch & Brake right? ok.
Well everything is hooked up but when I turn the key, it wont even attempt to start because the clutch has a sensor that goes to it, but my interior harness does not have that sensor, so even though I'm pushing the clutch in, the computer thinks I'm not since its not getting a signal, so the motor won't start.
just hard wire that circuit, and make sure you're not a moron leaving it in gear/clutch out when starting. somebody tell him where that circuit would be on the auto harness? theres gotta be a place to ground (I'm assuming it needs ground?) it, right?
Can you roll start the car for proof of concept at least?!
