sooo yea i know what everyone will say. save it. im just wondering.
i have roadmagnets. prolly going to get coils in the future but i want like 1inch drop in the front..
now what am i going to **** up if i do a little snip snip?
its not a deff i just want opinions. am i going to sacrifice anything?
you will stiffen the spring rate and lower the car
the problem is with the seat. if they are closed end, it tends to be a problem since they are meant to sit on a complete circle. when you cut even a little, then you create an open end and they tend to sit crooked, rub the strut etc
if they are stock open end then the perch has a little pocket for the end to nest in and a ramped shape part way around.
perfect for a little trim.
How much ? .................... ah just like adding salt
you can always trim more, you can't put it back
I have not looked at the fromts, the backs are quite small
there a 1/4 turn would be a good start full turn would be a rather slammed ride. thats a guess of course. but I have 6 full sets of springs on a shelf in my garage for the rolla. and I have trimmed several of them, made perches etc
remember, a spring is nothing more than a coiled torsion bar, you are in essence twisting a long bar when you hit a bump. If you cut the bar shorter you have to twist a shorter bar which makes for a stiffer rate. ultimately you would get to the yeild point, but in this application you'd coil bind way before that
Oh, a torch?? ugh a 4" die grinder or a drill with a cutoff blade works fine
one other vital thing
your struts are set to work with a specific spring rate by altering the rate you will have an oversprung, underdamped car which WILL handle worse than stock
