Would you guys know where the horn is located? Thanks.
between the grill and the radiator on the passenger side. I think you gotta take the black plastic piece that runs along the front of the engine compartment (right above the front of the radiator) off then it will be right there on the left (facing the car) towards the top.
yes you pull off the grille. IIRC, there's one screw on each end. Then you grab it and give it a hard yank up and towards you.
True but don't forget the two plastic fasteners on the backside of the grill that go into the body. Use a regular screwdriver to pull the screw out.
