Horn?
Would you guys know where the horn is located? Thanks.
between the grill and the radiator on the passenger side. I think you gotta take the black plastic piece that runs along the front of the engine compartment (right above the front of the radiator) off then it will be right there on the left (facing the car) towards the top.
Thanks because its not working and I wana check it out idk if its a fuse or not.
Its that black circle in the grille on the left hand side (passenger side).
he gets to it through the top doesn't he?
unless you go through the grille which I don't think is right.
yes you pull off the grille. IIRC, there's one screw on each end. Then you grab it and give it a hard yank up and towards you.
True but don't forget the two plastic fasteners on the backside of the grill that go into the body. Use a regular screwdriver to pull the screw out.
Yeah, these seem to give frustration to a lot of people who forget they're there.
