they are off an '07 MR, paid 1000.00 to a guy on Craigslist. I've seen them listed a few spots from 1000.00-1200.00 for a clean set. The seller I met with wanted 1200.00 but took 1000.00. The tires came with, but they are worn a bit funky because Evo's have funky alignment specs. The guy I got them from clearly didn't rotate them! Another thing to consider is that the "mag style" lugs will cost you 130.00 if the guy you buy them from doesn't have a set, so it could be a bargaining chip for you. The stock Evo lugs work with our studs (12x1.5.) Lexus uses the same set up as well. With rolling the quarters, you really need to do this before you mount them. I learned the hard way and cut into my rear tires. Front fittment is perfect!
