What MPG do people with stock MSPs get?
i get 24.38 mpg in the city. Thats getting into boost sometimes too. Highway I get 32.76. I drive down to Miami and still have over half a tank. We have this car at a good time!
Ive gotten up to 30mpg.. Stayed out of boost most of the time though.. Also, the gas light comes on when there is 2 gallons left..
Not mine, its usually less than 1 gallon. I pump beyond when the pump stops so its completely topped off. Often can go up to 80 miles on the highway before the needle drops down to "F" mark unless I am boosting a lot.
Well, I been watching my mileages over the last 2 tanks.
I run alittle over 400 miles to the tank with mixed driving.
I take the tank to the light and then some. so by the time i fill up i do fill to about 13.9-ish once I took it to 14.2..
Not true. Reset your trip odometer every time you fill up. When you fill up divide the miles showing on your trip odometer by the gallons the pump shows when it clicks off. If you always fill up to the same point, you'll get accurate numbers.
This works whether you refill at 1/2 tank, 1/4 tank, or negative E
This is very true. I second.
with the aem intake, 2.5" custom turbo backwiithout the cats i get around 400-450kms in town which works out to around 25-28 in town.. on highway i havent had a full highway trip without in town driving but with a 400 km highway trip taking it easy, and prob 100-150kms in town.. worked out to be around 35-38.
Thats weird, because I had put 3 gallons in it from when it was empty (yes I ran it completely out of gas) and at 27 miles the light came on, then it ran completely out of gas at 90 miles..
