dragtillidie
- 03.5 Mazdaspeed Protege
i get 24.38 mpg in the city. Thats getting into boost sometimes too. Highway I get 32.76. I drive down to Miami and still have over half a tank. We have this car at a good time!
Ive gotten up to 30mpg.. Stayed out of boost most of the time though.. Also, the gas light comes on when there is 2 gallons left..
Not true. Reset your trip odometer every time you fill up. When you fill up divide the miles showing on your trip odometer by the gallons the pump shows when it clicks off. If you always fill up to the same point, you'll get accurate numbers.
This works whether you refill at 1/2 tank, 1/4 tank, or negative E
Not mine, its usually less than 1 gallon. I pump beyond when the pump stops so its completely topped off. Often can go up to 80 miles on the highway before the needle drops down to "F" mark unless I am boosting a lot.
