Here's one for you Mid_Life, to make myself look like more of an idiot... How do you read those tables on Falken's site??
They say your Azenis 225/40-18 has a load rating of 92. The MS3 weighs in around 3200lb with a 60/40 weight dist. That puts 1920 up front and 1280 in back. Looking at the 92 row on the reinforced chart, 1280 is roughly 38psi, and 1920 is off the chart (>42psi). I'm retarded, so can you please explain how you read that chart to arrive at your 41/39? Are the numbers listed not front/rear weight splits? Corner weights make even less sense.
