Just for Swampass.....(intercooler H2O Sprayer)
Demi
Well Swampy always enjoys my misguided antics, so this is for you buddy.
With the constant heat here in AZ and my front mount still being built, i thought i would do something to entertain myself for the weekend and build a water sprayer for my top mount. Picked up all the stuff at Autozone and Ace Hardware. It looks ghetto because i messed up the paint, but it really does work. Usually after a spirited romp my top mount is hot to the touch. With this its ice cold. More so when i use ice as you might imagine.... Anyway I just used a back porch mister setup, a 12 universal wiper pump, a toggle and a generic reservoir.
This wasnt gonna go on there.....sooooooooo.....
This tip did the job quick like.
This is were i mounted the pump and the res is just zip tied.
This is where things went horribly wrong. I had to do more bending and cutting and all the paint chipped off making it look a like a bag of ass. Oh well.
The switch looks good though, and when i take it out the ashtray will cover the hole.
I just zipped tied it down.
Again, i know it looks horrible, but it works and is a noticeable difference when the temps climb. Ice in the res helps even more. I doesn't leak to the ground because its a mist and evaporates before it gets that far so i was able to use it at the track. In these pictures the hose is kinked, it make a mist just like it you would expect.
Why does it look like a paint spray can exploded on your IC?
Directly under the IC are the spark plugs. Are you using anything to block water from getting to them? If so, please share...
Yeah...............:( If i just hadnt tried to paint it. I knew better too. Ahh well no one sees it but you guys.
Dude, you might be the next contender for the Red Green show. I had mistaken your genius for slap togetherness.
