I'll be glad too, there's actually a thread the came before this one about the exact same if you care to look at it. Something along the lines of coolant bypass. Here we go.
A throttle body has engine coolant that passes through it in order to keep it warm, the purpose of this really only applies in cold cold climates. It's to keep the throttle body from freezing in an open or closed position. So if the throttle body is being heated by the hot coolant, than the air that passes through it is also being warmed to an extent. Kind of reduces the effectiveness of a cold air intake. So bypass the throttle body in the coolant line. All you need is an adapter with two male ends that will enable the two hoses attached to the throttle body to connect to one another while still enabling the coolant to go where it needs to. Now no more hot throttle body thus colder air.
