FS: Aeroforce Scan Gauge for ms3/6 (new - open box) $220 shipped obo
Status
Not open for further replies.
Selling my Aeroforce scangauge to raise money for some other secret projects (ricer) I got this on the $224 shipped GB last month; regular price is $239 USD + shipping.
I am asking $220 or best offer - shipped. Oppened the box to check it out of course but it is new.
Pictures
Samle install
Features
http://www.aeroforcetech.com/Mazdatech.html
So what is an Aeroforce Scan gauge?
Its an OBD plug and play Scan-gauge that can read/display numerous Factory PCM data
How will having a Scan-gauge help me?
This amazingly powerful 2 1/16" (52mm) gauge provides real time information allowing you to diagnose problems, measure performance, fuel economy, and read and clear trouble codes. It does it all and looks great too! Not only that, but its a Plug and Play operation...No wiring!!!
What can the scangauge display?
For your mazda3/6 & MS3 and MS6 owners, the gauge can display:
RPM
MPH
Knock Retard !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Intake Air Temperature
Intake Air Temperature 2 (charge air temp)
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor (A/F ratio, Lambda on vehicles with factory wideband)
Commanded Lambda and A/F ratio
Fueling status (open/closed)
Wideband sensor output current
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger applications)
Ignition Advance
Engine Run Time
Battery Voltage
Throttle Position Percentage
engine Load
Direct Injection Fuel pressure
Calculated Horsepower
Instantaneous and average fuel economy
2 user configurable analog inputs**
Injector Pulse Width
Injector Duty Cycle
OBO does not = desperate for cash. its normally 240 + 20 for shipping, no reason 260 of value depreciates 38% because the box is open. i am flexible but that is a bit too low
please pm me offers/negotiations
I didn't mean to imply you were desperate for cash. That was clearly not my intention.
However, yours is worth what I offered to me as it's not the color/style I would have purchased myself. That's less than you'll take apparently, so good luck with the sale.
Status
