In reality, if you have no plans on upping the boost with a controller then you really don't need one.
IF something fails the ECU will go into limp mode. Try again.(hand) There is a reason for boost/fuel cut.(smash)About as far from the truth as you can get. A boost gauge is a very good thing to have and EVERY boosted car should have one, because if something fails i want to know if my can starts boosting 30psi instead of stock 18 or so.
Autometer is a great mechanical and i loved it on my msp, easy install and everything
Read my above post again...after all you quoted it.yeaup ok, and then once you put some kind of controller on there, s*** can go bad. plus boost is somehting you want to monitor in a turboed car, plus monitoring boost to adjust your driving habbits is a great thing also.(I believe someone previously stated this.
But as far as the electrical being more accurate. Yes in a way and it does have its advantages as to install. But unless you want to drop a pretty penny mechanical will suite you just as well.
