Turbine Tech Front Engine Mount
Rican219
MazdaSpeed 6
I installed mine tonight and THIS IS THE WAY THIS CAR SHOULD HAVE BEEN DESIGNED TO DRIVE!!!!!
Man that thing solved every complain I had. Smooth Shifts, My front wheels feel like they are going to break loose with the newly found power. WELL WORTH IT!!!! Vibrations from the rear mount gone. LOVE IT!!
Pain to install.
Rican man what the hell kind of site is that!?! Lol.. Oh and i got my SS yesterday!! Im installing it today!
They're in Canada and the website is in french.
Here's the mount. You can buy it on ebay, or call them directly-they do speak engilsh.
I'm not too worried about the front engine mount, but their diff brace and diff bushings look promising for $329.99. Did you get the entire setup (diff brace, front mount, bushings) or just the mount?
Entire setup and Installed all of it today and all I can say is WOW!!!! The car is not the same!!!
Thank god, we were tired of hearing it. We don't want to hear any more from you now. (rofl)
So did you have to drill holes in the subframe to install?
BWAHAHAHA Sorry
Yes there are existing holes there you just drill the holee so the bolt will go all the way through
I just got all my parts (front engine mount, diff mount, rear diff bushings) from the GB and everything looks top notch. Can't wait to install them.
How bad was the install for the rear diff stuff? I'm really interested in this, since I don't want to be blowing diff case bolts out.
Front Motor Mount I did myself it was a Pain but not to bad. 2hr Install
Rear Diff mount and Bushings I looked at it and toooo much involved for me to try myself so I had a shop do it. IT SUCKED!!! Took them 3 hrs to do the install. Easiest way they found despite the instructions stating to drop the gas tank and blah blah blah the shop dropped the Sub frame to do it and that appeared easier.
A lift is needed to do that part of the install by what I can tell I mean I very handy with a wrench but it helps to have a lift and a Tranny jack.
i was reading about this over on the other forums..... but they were all only talking about, it's nice to have heard from someone who actually installed it, when I have a little more free time I'll check to see the price for the entire kit, since I haven't jumped the band wagon to buy a front mount yet.
I did the rear mount, rear bushings, and the whiteline swaybar today in about 5 1/2 hours. it's not terribly difficult, there are just alot of hard to reach bolts, and the OEM swaybar is a PITA to remove...
This ranks right up there with the DP in terms of improvement over stock...
Thanks, I forgot to check the damn prices, I'm gonna go check now.
and as for your review, it's pretty much been the be all end all for me to decide this really is worth it, I think i'll get the kit someone mentioned that has the front mount as well. that should be better than the CP-E or AWR front mount, right?
I really think I'm gonna get the diff. mount this summer with the bushings, I've read nothing but good things so far on both forums.
cp-e and awr dont make front mounts they make rear mounts.
