Royal Purple
Killer
2011 3 5 door
Anyone switch out the tranny and drive line/diff oil with Royal Purple synth gear oil? And if you did...any noticeable differences?
You can use Amsoil and get the same results.It works better than the factory fill,very noticeable in cold weather.
I do Mobil 1 in the engine....but I hear royal Purple is the best for the driveline.
I have used RP in the tranny and rear of my 2004 GTO(SOLD) and thought it helped a bit but was mostly piece of mind
any of the good quality synthetics would be fine as it mostly comes down to choice
similar to oil for the engine, most every synthetic is great as long as you use the proper weight
im running royal purple right now i wanna swtich over to 0W-30 AMS oil.. i have redline MT-90 Tranny Fluid in the tranny but i was thinking of using royal purple for the transfer case anyone using that and noticed a difference.
Thanks.
I was going to but I was told that you don't feel much of a difference to use Redline instead for Tranny and Rear Diff. I use RP motor oil. I'd like to see where this thread goes.
Do you think its better off to leave that stuff factory sealed and untouched?
Just in case an issue comes up it cant be blamed on the fluid. Rear Dif's and Transmissions are $$$
after seeing what came out of the factory diff/trans fluids when i drained it out at 30k miles, I highly recommend changing your trans/diff fluid on a regular basis.
I use it as motor oil.
i may be reading into this post too much, but do u mean u use Royal purple gear oil as engine oil........or u use royal purple engine oil as engine oil.
if its the first of the 2.......hwo is it. does it work well?
