Anyone switch out the tranny and drive line/diff oil with Royal Purple synth gear oil? And if you did...any noticeable differences?
I do Mobil 1 in the engine....but I hear royal Purple is the best for the driveline.
I have used RP in the tranny and rear of my 2004 GTO(SOLD) and thought it helped a bit but was mostly piece of mind
any of the good quality synthetics would be fine as it mostly comes down to choice
similar to oil for the engine, most every synthetic is great as long as you use the proper weight
Do you think its better off to leave that stuff factory sealed and untouched?
Just in case an issue comes up it cant be blamed on the fluid. Rear Dif's and Transmissions are $$$
I use it as motor oil.
