here is a little lesson with how the "boost cut defender" works on this car for those who are uninitiated. the boost cut defender bleeds off any boost above certain point so that the MAP sensor cannot read anything beyond that point. the MAP sensor, among other things, is responsible for telling the ECU how much positive pressure is in the intake manifold. this allows the ECU not only to trigger a fuel cut (hence the stutter or brick wall feeling some of you get) when it sees over boost, but also determines the proper fuel mix, the proper amount of timing pull and potentially the amount of throttle plate closure.
so lets say that you are 15psi. the computer will see 15 psi and add X fuel and pull Y timing. if you are at 16, 17, 18, etc psi, the computer will still see only 15psi and still only add X fuel and Y timing. the problem with this is obvious. the more boost you run, the more fuel you need and more timing pulled to maintain not only a safe AFR, but prevent detonation and generally keep a safe engine operating condition.
so yes, the "boost cut defender" does allow you to trick the computer so you can run more boost, but it also prevents the stock computer from really doing its job. the car does not tune by MAF sensor alone.
i don't know if volumetric efficiency has even been discussed in this thread, but it should be. 15psi on a K04/22 is not the same as 15psi on a GT30anything, 71 or 76. Its like saying a straw pushing X psi of water is the same as a sewer pipe pushing X psi of water. Bigger turbos push more air, period. Its - no offense - stupid to say "well the turbo came at the set wastegate pressure of 15psi and i have a boost cut defender and my AFR is nice and rich" and use that as a blank check to think your car is safe. its not that simple folks. there is cheap speed and reliable speed. there is no such thing as cheap and reliable speed. if you shove more air, more VOLUME of air mind you, it will put more of a strain on the engine. it does not matter if you run the same PSI as before. it does not matter that your air fuel ratio is perfect. these engines, as i have been saying all along, are really not that strong.
so lets also address the people who just push more boost from the stock turbo. that too is not such a great idea. someone ripped me a while back for saying the turbo is already close to or is maxed out in terms of efficiency. his counter argument was "well i made more power by running more boost so you are wrong." just because you are making more power does not mean you are in the efficiency range of the turbo. and the worst part about that is that you are now forcing hotter air into the engine. hotter combustion temps, hotter intake charge do not mean good things for the life of the turbo or the engine.
