pHeeL tHiZ ViBe
- Mazdaspeed6
haha forged for sure! no way i would slap a turbo on without that first, let alone a turbo that big!
its estimated power and an estimated weight done by this calculator: http://vmaxoutlaw.com/tech/horsepower_calculator.htm, obviously it cant add factors like temperature, tire psi, 60ft times and thats why its an estimate.
Also the GT3076r flows alot more power and cfm then the gt3071r. And they only make similar power levels when the 3076r is operating on lower boost. After 22psi the 3076r shines and can make a little over 525hp at its maximum boost level
Purchase everything separately and have your local Mazdatech do the work to build your current block bottom end. Unless you know how to use a cherry picker and pull the motor yourself and do all the work, it's going to be expensive regardless on just labor.
unless you are really buddy buddy with a mazda mechanic i guarantee you buying all the parts separate and having the dealer do it will cost you as much or more as buying one of our motors.
i would be willing to build an old motor, however i would only feel comfortable doing so after a machine shop inspects the engine and does - if need be - a bore and hone, which i would charge for.
now i dont have nearly as much experience with this specific engine as some of you, but i do have alot of experience elsewhere, and it seems this engine is in the same boat as MANY f/i engines out there.
WEAK stock cooling and an inefficient turbo means either
A. stick with close to stock boost levels, upgrade to a more efficient intercooler (preferably front mount due to heat soak) and take advantage of the boost you are already making instead of adding more.
B. upgrade to a larger turbo, and a front mount or very efficient top mount at the least.
90% of the time on a forced induction engine it isn't power that kills it it is bad tuning, or just high temps in general causing detonation/knock. I dont care what kind of rods you have eventually with alot of knock running high cylinder pressures you are GOING TO BREAK s***. this is not a generality, this is FACT on all engines. 15 psi out of that weak ass top mount that already has major disadvantages when it comes to heat soak, along with it being air-liquid (more heat soak issues) leads me to believe ALOT of you modded guys are detonating grande style. This guy blew his motor because of major tune issues, not much else. I'd be comfortable betting you that you guys would be very impressed by a more efficient turbo with a big front mount and a great tune and it would run for a looong time. it sounds to me like because some people went down the wrong path mod wise (learn from it, dont let it make you afraid) you guys think all your motors are gonna grenade. Well that's what people used to think about the car i currently drive (2006 4.0 v6 mustang). Now we have more than 3 cars running 11's on stock blocks/trannies and one in the 10's consistently on the stock block....MANY in the 12's. Hell one guy was making almost 600 ft lbs on a 75 shot and 15 psi from a big snail for over a year before he blew the #7 piston spraying WAAAY to early (window switch broke). This is with hypereutectic pistons that people were blowing with vortech's on 10 psi at 310rwhp. You know what made the difference? A good tune, and cooling mods.
all of you-
DO THOSE FIRST. boost control = last thing you want to do safety wise on any turbo car. Do cooling and exhaust mods first and you will see good gains, much more safely. Its amazing to me to see how many people do the opposite when i dont even own a forced induction car and i preach this daily to all the ricers at my school driving turbo hondas at 7 psi with no intercooler and new motors within a month.
i honestly stopped reading this ramble. sorry dude (laugh). /handsthemanacapt.obviousaward
all of you-
yea thanks for that. It's too bad it's obvious because that just makes half this forum look retarded.
?? what is your IQ seriously i'm curious
2. don't get # greedy, and never turn up the boost without a tune. Is 15whp worth increasing your risk of internal engine component failure even by 5%?
127 average of all the tested types of intelligence when i took the test. Highest was i believe a 132, lowest was around 105 why do you ask? I have been on the msp forums, these forums, etc. and i see MANY people with boost control with no form of tuning. That's not a great idea in ANY car let alone an msp or ms6/3. Obviously, it wasn't too obvious because you are following suit...
since it wasn't obvious enough for you even though you feel like being a smart ass and talking about how obvious everything i said was-
1. do cooling mods first, you will gain power just like everything else, you will need them eventually and they may save you in the long run.
