Trailer Hitch for CX-7
Is it possible to "remove" the OEM trailer hitch that came with my new CX-7? (bought it two days ago) - i.e. without cutting into it?
I'd be willing to part that out since I'd never use it (why did I get it you ask? everything else in the vehicle was perfect and it came with it in + no additional cost to me).
Can anyone explain to me what the different class's of hitches mean? Class I, II, III, upper class, lower class, Physics class??????
First time owner of a CX-7, GT, AWD.....love the car and want to get a hitch to haul utility stuff.
Yes
If it is a Mazda hitch it is bolted on.
If it is an after market hitch your dealer had put on it may need to be removed with a torch.
The larger the number of the class of hitch the more weight it is designed to tow.
So my old C2500 trucks class 4 hitch could tow 10,000 lbs. I routinely towed a 2,000 lbs trailer with a 3,000 lbs car on it.
Class 1 (Class I) hitch
Trailer hitch with capacity of up to 2,000 lbs gross trailer weight and 200 lbs tongue weight.
Class 2 (Class II) hitch
Trailer hitch with weight-carrying rating of up to 3,500 lbs gross trailer weight and 300/350 lbs tongue weight.
Class 3 (Class III) hitch
Trailer hitch with weight carrying rating of up to 5,000 lbs gross trailer weight and 500 lbs tongue weight. Also sometimes used to refer to a hitch with any 2" receiver, regardless of rating.
Class 4 (Class IV) hitch
Trailer hitch with weight carrying rating of up to 10,000 lbs gross trailer weight and 1,000 - 1,200 lbs tongue weight. Although many times any hitch with a capacity greater than 5,000 lbs gross weight is referred to as a Class 4.
But if your manufacture rates your vehicle less, listen to them. They are basing this on items like frame/body strength, spring rate, Braking power, power from the engine, rear end strength, transmission strength etc..
You can put a class 3 or 4 hitch on but when loading a heavy trailer the required tongue weight to keep it stable will exceed your vehicles rear springs and when you shift the weight off the tongue it will start whipping back and forth when you try to go even 55 mph. Many people who buy these little Japanese Pickup trucks fall for the 1/2 ton rating towing capacity. They just are not safe to do this. I know the guy who purchased my Brother In Laws GTO drag car and trailer showed up with a Toyota 1/2 ton to tow it home. We advised him to go back and rent a Full Size truck and come back. He informed us that the Dealer assured him that it would tow 8,000 lbs so this would be no problem. When he loaded the car correctly the springs collapsed to the frame. So he moved the car back until it raised it up a bit. He got on the freeway and got only 5 miles when its whipping got worse and worse as he speeded up to 65 mph. Until the Car/Trailer departed the highway Towing the Toyota Pickup backward off the freeway totaling the whole thing.
Right, I understand that the manual states you can't (shouldn't), but can the 7 tow more than 2000 lbs without an issue? Obviously, I don't expect a true answer, but if it can tow 3500 lbs in Canada, why should there be an issue in the US???
Rest assured, the manual in Canada also states 2000 lbs.
The 2000 lb limit is a factory safety limit. The 2000 limit means that you should be safe to pull from one side of the US to the other. I doubt any problems would ocure if I pulled a 2800 lb boat for 30 miles here in flat FL. Common sense rules of course.
Hmmm... i thought for sure someone posted on here that 2wd was 2000lbs and AWD was 3500lbs in Canada.
Now of course I can't seem to find it so it may have been my imagination. (Or they were wrong and have since edited their post.)
@ azcat
You really make me laught... We had to meet next time I will stop @ The Dragon, with my CX-7 hauling our FZ1 and FZ6 bikes (my wife's and mine)...
Ride safe!
Let know how it works. Since the wife made me sell my Truck after I got the CX7 my FZ1 has had to ride to the track... FZ1/CX7 what is not to like(wiggle)
I have the Mazda hitch. With the wiring. It works great. Is tucked up nicely and the wiring works lighting up my Terminator Skull Hitch Cover...(cabpatch)
While I doubt this is true, if anything, it'd be the opposite.
I FOUND it. Go to post #28 of THIS thread.
I knew I read it somewhere.
Now I'm not saying this person is right, I'm just saying that I knew I read someone say it.
Though I wouldn't neccessarily agree that it would have to be the opposite. The AWD models of some cars come with transmission and oil coolers and larger brakes. (I don't know if this is the case or not with the CX-7).
My parents had a 2WD Ford Aerostar and didn't like it in winter so they went to the AWD Aerostar and it had a higher tow rating.
Well according to post #52 of this thread it's 2,000lbs (cabpatch)
I think that probably the writer of the article just made a mistake. The 2,000lbs is pretty universally documented
U Haul
My last three hitches have all been U Haul.
Not only have they been quick and clean installs, they guarantee their work.
Class II is fine for small trailers. Remember the Cx7 will only handle up to 2000lbs.
Thats what I have planned for my new Cx7
Anyone know which aftermarket trailer hitch fits 2010 CX-7?
I cant find any info on it.
mount points should still be the same. i'd guess if there is any difference they haven't developed it yet.
Greetings from Mexico everyone! I just got my brand new 2011 CX-7 GT AWD and am now looking to install a hitch to keep towing my usual weekend sport stuff (about 250 lbs total). I used to have a 2" Curt Class III hitch on my 2008 Honda CRV but from what I've been reading here a Class II hitch (1 1/4") seems would be enough for my needs for now. I've seen also Class I hitches rated, as the Class II, at about 2,000 lbs total weight.
Can anyone provide some input on the most reccomended hitch to go for? Will not purchase the dealer installed one as it goes upwards than 600 USD down here.
Thxs
PPG Mexico
What is the max load that the CX7 can handle when pulling car trailers? I have show car that I used to tow on a car hauler using my Jeep (that I am trading in). The Jeep is AWD with a V8 so it handled very well. I am worried that if I try with a more luxurious type of vehicle. There are several posts with different type of hitches that everyone recommends, thanks for this! Most have said that the drawtight is also the easiest to conceal...anyone care to differ?
