What have you done to your MS3 today?
Working on getting the MS3 murdered out (as Rob & Big would say) with some new wheels & BFG tires.
them thangz iz hot.
BTW on my way to the bank this afternoon I saw a horrible excuse for an MS6. It was black cherry in color and it had close to 22" inch chrome DUB's on it from the look of it. Absolutely disgusting.
Washed it and applied my own little guilty piece of customization on the rear hatch :P
BC coilovers! Too tall in rear! must adjust. Otherwise, very nice addition.
did you install camber plates up front? How. Do the Bc adjust the rear height with a spring insert? And lastly, well there is no such thing with me, what rate springs did the BCs come with? Thanks mister.
Today/// yesterday, recently, the weather got warmish. so out comes the Mazda! So i rotated the tires. switched to Muteki blue nuts from Gorilla black. Checked out the brakes and the nuts and bolts from last falls suspension upgrades. And finally gave the AEM air straightener a good run through the ringer. I have a dealer installed MazdaSpeed Cold Air. I am fairly impressed with the results of a 15$ part. My fuel mileage started to rise and the missfire in third at 4500-is gone. Last fall i was sure i had ignition issues. Also I received my colder Denso plugs from Street Unit. Just in time. Wow i sure missed driving my baby. I can't wait for spring time
I drove my MS3 about 30 miles, but the big news was that I pulled the car cover off the 2002 and it fired right up- after sitting for over two months. Not bad for a 34 year old car...
You have the spin on conversion, right? How's that been holding up so far? Which one did you get?
The one from PG (the Mazda part). So far, no leaks. I looked closely when I took the belly pan off this morning -- no sign of oil trails, etc. The combination of the Quick Oil Drain valve and spin-on filter made it a piece of cake. Still was an $80 oil change (omg) less the bulk purchase discount.
^ Epic fail. The gasket is removing the paint I put on. I used duplicolor high temp engine paint. I guess I should have let it cure for 7 days before putting it back on :)
i pc'd mine a matte black...leaves a slight mark still...not rubbing pc off...just a movement mark...the matte finish helps hide it A LOT...
