tuOdekcalB
- 09 Mazdaspeed 3
15% tint all around
thanks dude cant wait to see your stuff installed.nice wheels!
Working on getting the MS3 murdered out (as Rob & Big would say) with some new wheels & BFG tires.
did you install camber plates up front? How. Do the Bc adjust the rear height with a spring insert? And lastly, well there is no such thing with me, what rate springs did the BCs come with? Thanks mister.BC coilovers! Too tall in rear! must adjust. Otherwise, very nice addition.
Oil change at 8,500. 6 1/2 quarts Pennzoil Platinum, NAPA Gold 1516
The one from PG (the Mazda part). So far, no leaks. I looked closely when I took the belly pan off this morning -- no sign of oil trails, etc. The combination of the Quick Oil Drain valve and spin-on filter made it a piece of cake. Still was an $80 oil change (omg) less the bulk purchase discount.You have the spin on conversion, right? How's that been holding up so far? Which one did you get?
^ Epic fail. The gasket is removing the paint I put on. I used duplicolor high temp engine paint. I guess I should have let it cure for 7 days before putting it back on![]()
i pc'd mine a matte black...leaves a slight mark still...not rubbing pc off...just a movement mark...the matte finish helps hide it A LOT...
