Strut Endlinks or Sway bar stablizer end links what ever it's called...
Vangpride
03 P5 - Midnight Blue
So i'm going to be changing my struts, would these need to be replace as well? people keep saying to grind or cut them and is that an option? Can't you just unscrew the bolt? Btw does the rear have those endlinks that connects to the struts also like the front? My damn Air impact wrench tool actually stripped the bolt to it and my brother is going to take it to a shop and check it out. Going to have all the bolts loosen.. Need some help here on about the endlinks and if it does so happen that i need some i will be looking at RockAuto ftw. ^^
I had to cut mines -i believe they were the original ones that came w/ the car.
It was not fun either. Try getting a really good penetrating oil prior to attempting to remove the endlinks.
