M MSP-4-ME Member : 2008.5 Mazdaspeed 3 Sep 11, 2003 #1 I am going to remove the MBC to get the ECU flash tomorrow and was wondering about the original T-fittings that were glued together. Are you guys glueing the tubes back on the T-fittings or just sliding them on? Thanks (mspblack)
D DiscreetSpeed Member : 03 MSP Sep 11, 2003 #2 i just slided it on just make sure it goes in all the way. theres not alot of pressure running through there to blow off, unless you barely put it on.
S SaaBaaDoo Member : 2007 White Diamond Pearl Acura TL Navi Sep 12, 2003 #3 what happens if the wastegate to the T hose comes loose???
