FM doesn't have any timing control for the Protege as of yet. I believe they might be working on it though. I'm sure it will be a modified Link unit like Terry's. The thing that I like about the J&S is this. If you don't want crazy horsepower like 250+, the J&S is perfect. It not only retards the timing when it hears pinging, it also actively retards when you hit a certain psi level. So it is half active timing control, and half passive timing control. It doesn't give you the total control over your timing curve like the more expensive Link or stand-alone systems, but for this motor, I don't think that is necessary unless you want to run the turbo at 10psi or more. Also, stand-alone systems won't "save" your motor if you have a malfunction of some kind, the J&S will.
