Laser Blue Protege5 Build
So, now that I am in Southern Arizona, I don't have to worry much about passing emissions, thus I can start looking at the turbo conversion. However, where do you find the turbo manifold? I know there are many other parts needed, but one way or another, I am certain I can source them. But I can't find a source for the turbo exhaust manifold, even aftermarket. I must suck at internet searching......... Any help?
I’ve been looking too, at least for something aftermarket. If I find a good one I’ll send you my old one. Or if you want my old b series manifold and t3 turbo it just needs the downpipe mated to the midpipe and some repairs. There’s also a top mount turbo manifold I see on Amazon but that would take a custom downpipe.
Ok, we'll keep in touch. I did find a cast one on Amazon: https://www.amazon.com (commissions earned)
I am getting my intermediate pipe cat removed next Monday to just straight pipe it.
Well, was going to have my intermediate pipe/cat taken out and fabricated into a 2" straight pipe. Shop first told me no more than $200, but when I got final estimate before dropping it off, they said somewhere between 490 and 575. I told them forget it, I will do something else. Researching now, I think I can fab it up with exhaust flange pipe adapters and straight pipe, clamped at first, but once I get it right, I can take it to a friend that can weld it solid for me and I can bolt it back in. Unless someone here knows who sells the intermediate pipe minus the cat. Got any ideas?
So, within the last couple of weeks, my clutch pedal started sticking whenever I held it down too long. This obviously presented some issues getting in and out of gear and made driving a little difficult. I bled the system at the slave cylinder a couple times, but it didn't really help. I figured next course of action is to simply replace both of the cylinders since they were original 22 year old units. The new ones arrive tomorrow, so I took the old ones out tonight. Not trying to rub it in, but it is so nice working in a garage with air conditioning and the convenience of a sink to wash up after working on the car. I've also included another picture of the headers. Also, the box on top of the car is a new set of Pioneer speakers for front and rear doors. Sorry some of the pix are rotated. That is how they loaded here and I can't figure out how to rotate them back.
20250815_215952.webp 20250815_220003.webp 20250815_220647.webp20250815_222610.webp 20250815_220624.webp 20250815_222635.webp20250815_223613.webp 20250815_220702.webp 20250815_220612.webp 20250815_220630.webp
I've had my P5 since '03 when I bought it brand new from the dealer.
Somehow it still has all of the stock speakers in place. Man I've been wanting to upgrade for a LONG time but just haven't gotten around to it. Those Pioneers should be a huge upgrade.
Merry Christmas to all P5 Brothers and Sisters. I did get the Pioneers speakers installed and with the factory sub and tweeters, wow! It is such a deep and immersive sound in the whole car. I turn it up loud and nothing distorts. Very satisfied. I still have the original P5 speakers so if anyone is interested.....
Also, I have a complete front suspension and steering linkage kit to put in, maybe this weekend. It still feels good, but I need an alignment and am getting coilovers soon, so I thought I would freshen up all the original components, get the coilovers, and then the alignment. 17" wheels and tires are in the works, along with a plastidip spray job, something like this:
Hey if you don't mind, can you post the Pioneer part numbers? We're also rocking originals and would be a nice move up. Thanks! Also, I just had the rack and pinion replaced with an original Mazda part someone left on a shelf and outer tire rods. Made a world of difference.
Ok, so I finally refined the mix of LED bulbs in the instrument cluster. I've got the main gauges all blue now, the warning indicators on the right a deep red instead of pink and I put the incandescent bulbs back in the turn signal indicators because they were too bright and distracting with white LEDs in them. Before and after:
Remnants of the guts in 2nd Cat and the tools that made it happen. Seems to breathe a little better! Sorry I didn't take any other picture during the process, but I was under a time crunch.
This was from the secondary cat?
I plan on doing the same when I install my header.
Breathing better is my whole intention with the header and hollowed out cat on a stick exhaust. 👍
Yes. I pulled the intermediate pipe to try to clearance the headers flange from the oil pan and while I was at it, I took a grounding rod and hammer to the catalyst in the secondary cat. It was still intact, but 23 years old. Took about 20 minutes to completely clean it out.
Good to know and now I know what is involved when I do mine.
Thanks. 🙏🏽
So, besides fooling around with the P5 when I can, I also have a 2015 Ford F250 Superduty. Just recently did a emissions delete, straight piped it and put a tune on it. It works soooo much better now
Guess I should have said it has the 6.7L diesel. I shouldn't assume everyone knows. This is also a benefit of now living in an non-emissions county in AZ
Spent a few hours this afternoon going to a PullNSave about an hour away to source a pair of 2002 626 calipers and brackets, as well as the valve cover (since it was already off). Met my son there and we checked out a number of other cars for future ideas and then grabbed some lunch.
I will get the calipers cleaned up and painted, ready for new rotors and pads. I grabbed the valve cover because I've read the coil-on-plug conversion required one. I will clean it up and paint as well and then get the other parts for the convert. Not sure if there are any great gains over stock, but I like the idea and look of it.
