CX-5 (possibly) Broken Into
2026 CX-5 Preferred
Not sure if they got in but the door lock cylinder is punched on our '24 CX-5.
Do late model CX-5s have a factory audible alarm that triggers when a door is forced open or is it simply a silent deactivation security system?
And, If the door was indeed forced open would there not be an alert when we turned on the ignition?
Also, I assume that I can simply replace the lock cylinder but the key will be different. I've had to do this on my CRV before.
No alarms and no security systems on US models for just opening a door.
Only thing that comes to mind is may be if using the connected/online services and the mazda App. May be it can send notification to your phone.
Really? If you ask the internet it says they come equipped with a factory alert system that beeps the horn extra loud and flashes the lights if the doors, hood, or hatch are opened. I have a hard time believing that not every single modern vehicle has this.
I guess I should test it out. My CRV certainly has it.
I am also interested to hear from anyone who has replaced a door lock cylinder in their CX-5.
I am not sure about that. the theft deterrent system is in the owner manual so at least some CX-5 models have it.
Yes. another cost cut by Mazda :) most of the sensors are missing in the US models, at least up to 2024.
So you're saying when you hit the button on the remote and it sets off the alarm, the car can't do that on its own if a door is forced open while in a locked state?
Mazda does make it really vague. The system is very subtle as well, people may have it without ever noticing. But I don’t know in the US if it is there or not.
The spec sheet for the 24 mazda cx-5 in the US says it has
  • Engine-immobilizer anti-theft system
But the Canadian spec sheet says:
« Engine immobilizer theft deterrent system »
The manual name them differently, with separate sections called: immobilizer system and another section called « theft deterrent system »
Correct. As I said above, US models don't have the alarm.
Nothing to do with 'sensors' (expect maybe a shock sensor). Just a software difference.
As I said, with the Fortin remote starter box, you can enable an alarm to go off if the door is opened while the car is locked. See: Fortin EVO-ONE Remote Starter - Install How-to Posted for CX-50.
To quote from that thread:
  1. Adds Car Alarm functionality for if a door is opened after locking (i.e. glass smash or jimmied & open) or the hood is opened/jimmied - no hood switch is required, it uses the factory one. Note: it does not come with a shock or tilt sensor, but there's a socket so one can be added.
Bottom line, I've no idea why Mazda doesn't enable it for our models. There's no cost difference to them.
lets agree to disagree. The one with real "alarm" has sensors in the cabin, as well as hood open/close sensor, etc. Then is the software on top.
your Fortin is sounding the horn if a door is open when car is locked. I guess it can work as sort of alarm.
Are you saying some Mazdas have a motion sensor in the cabin? That's pretty rare with anything other than luxury cars. My (other) GM car has a car alarm, but no cabin sensor. Similarly, my daughter's Ford has an alarm but no cabin sensor.
yes. Mazda has a real alarm option in other regions. There is also the el cheapo version too. Two types. Neither is in US models gen2 CX5 as far as I know.
My European CX-5 2023 (highest trim) has ultrasonic motion sensors in the overhead console.
Concerning the page from the manual in post #6… it doesn’t mention the car locking itself automatically when you (and fob) move away from the car after shutting the doors. My U.S. car has a tiny red light in the instrument cluster that blinks intermittently when the car is locked… I assume that means the car is secure and will alarm if opened incorrectly.
Leave a window open, lock it, then open the door through the window. That, or break the glass. :)
The red light was just for show on our '19. Maybe that's changed...
That:. Or alternatively the manual also says that the hazard warning lights flash when locking and unlocking doors with the theft deterrent system:
(With theft-deterrent system)
When the doors are locked by pressingthe lock button on the key while the theft-deterrent system is armed, the hazard warning lights will flash once to indicate that the system is armed.
When the doors are unlocked by pressing the unlock button on the key while the theft-deterrent system is turned off, the hazard warning lights will flash twice to indicate that the system is turned off.
The flashing red symbol in the dashboard is the engine immobiliser system. It is a different system (and it is a bit redundant now with push button start). That system prevent the engine from starting unless it detects a specific chip in the key. This used to prevent people from driving away with a copy of the key or without having the key at all.
The car locking itself automatically is not part of the theft deterrent system, that is the "walk-away auto lock function". It is in the manual on page 3-15
The security indicator light of the engine immobiliser system in the instrument cluster flashes twice per second for 20 seconds. After 20 seconds, the theft-deterrent system is fully armed.
