Well mine seems to have gotten worse. Smoked out the girl at the mcdonalds window this morning. Now pretty much anytime It sets at idle for 3-5 minutes it starts up and will continue as long as I idle. Its even giving up a little liquid splatter on the ground....[/QUOTMinweE]
My Turbo did the exact same thing. Ur turbo is ****** bro.and take it to the dealer.I also noticed a lot of soot build up in my tailpipe..like enough soot that if you wiped it with your finger you'd have an 1/8of an inch of soot on your finger
Are there a lot of 2008.5 with this problem or is it mostly the 2007 speed 3's.
I searched thru most of these "smoking" threads and have not found a clear consensis of what the problem is and if all the speeds potentially could have the problem.
I have only about 1200 miles on my 2008.5 with no mods. Have NOT had any smoking issues.
From what everyone seems to think, our turbos naturally let certain amounts of oil through the system anyhow. The catalytic converters are suspected to catch it all. When you start to remove those pieces or swap your factory exhaust with aftermarket, it starts to show it's ugly head. OR, the backpressure that you lose with aftermarket exhaust lets excess oil into the exhaust from bearing seals.
It typically doesn't happen to bone stock cars though. I've only see maybe 2 cars on the forum that had a smoking stock turbo.
It should be just coming from the exhaust. Sounds like you just have an exhaust or an oil leak burning off somewhere. Are you having to add oil?
